This command configures the LSA batch interval. LSAs added during this interval are batched together for update.
seconds | Interval in seconds. Range is 0 to 600. (Default 0, not batched). |
0.
The range is 0 to 600 seconds.
# show ospfv3 OSPFv3 : Disabled RouterId : 0.0.0.0 RouterId Selection : Automatic ASBR : No ABR : No ExtLSAs : 0 ExtLSAChecksum : 0x0 OriginateNewLSAs : 0 ReceivedNewLSAs : 0 SpfHoldTime : 3s Num of Areas : 1 LSA Batch Interval : 0s 10M Cost : 100 100M Cost : 50 1000M Cost (1G) : 40 2500M Cost (2.5G) : 40 5000M Cost (5G) : 40 10000M Cost (10G) : 20 25000M Cost (25G) : 20 40000M Cost (40G) : 20 50000M Cost (50G) : 20 100000M Cost (100G) : 10 Graceful Restart : None Grace Period : 120s Import Policy File : none SNMP Traps : Disabled Redistribute: Protocol Status Cost Type Tag Policy direct Disabled 20 2 --- none e-bgp Disabled 20 2 --- none i-bgp Disabled 20 2 --- none ripng Disabled 20 2 --- none static Disabled 20 2 --- none isis-level-1 Disabled 20 2 --- none isis-level-2 Disabled 20 2 --- none isis-level-1-external Disabled 20 2 --- none isis-level-2-external Disabled 20 2 --- none host-mobility Disabled 20 2 --- none
This command was first available in ExtremeXOS 21.1.
